| View previous topic :: View next topic |
| Author |
Age: 72 Joined: 27 Feb 2013 Posts: 1248
Posted: Mon May 21, 2018 9:37 pm Post subject: NEW GM and Yellow Coach Die-cast Models |
I found the following on the internet. They are under the name "IXO" and are listed as 1:43 scale die-cast models.
Can anyone give us the exact dimensions for these buses?
Any additional information is highly appreciated.
| Description: |
| Filesize: |
81.32 KB |
| Viewed: |
84875 Time(s) |
| Description: |
| Filesize: |
47.23 KB |
| Viewed: |
84875 Time(s) |
| Back to top |
Posted: Mon May 21, 2018 9:38 pm Post subject: |
Two more models
| Description: |
| Filesize: |
130.91 KB |
| Viewed: |
84874 Time(s) |
| Description: |
| Filesize: |
146.77 KB |
| Viewed: |
84874 Time(s) |
| Back to top |
TheDriver
Posted: Mon Jul 23, 2018 2:25 am Post subject: |
I saw these buses online and looked real close at the details. I like the fact that it is a larger 1/43 scale than Corgi so it is easier to see the flaws. I actually want a Rapido Trains version in 1/25th scale which is huge.
IXO might have done better than Corgi and Busch in some ways but also got the shape wrong in other ways. The rear window is off. The front may have been better in some ways but worse in others, but the glaring mistake for me is the front corners of the bus. Both left and right are off a lot. The real bus tapers like a dull pencil at about a foot from the front. The front pillars of the real bus are not very thick but the IXO model seems to show a very wide.
What they don't get is that the complex fishbowl shape makes it hard to copy. The driver's window is a place where a flat window goes into a curved place both vertically and horizontally. If you could see a real bus you would see a ledge with a very peculiar shape and the overhang to match. What many people don't know is that the windshield and driver's window actually overlap. It is more apparent when you are in the bus.[/b]
| Back to top |
Posted: Sat Nov 17, 2018 2:17 pm Post subject: |
Here is another IXO GM "New Look" model, this time is a TDH-5301 ex, Fifth Avenue Coach in MaBSTOA service, number 3165.
I like that they included the roof-top radio blister
However, the engine compartment hatch lights are wrong.
| Description: |
| Filesize: |
33.21 KB |
| Viewed: |
84007 Time(s) |
| Description: |
| Filesize: |
29.46 KB |
| Viewed: |
84007 Time(s) |
| Back to top |
TheDriver
Posted: Thu Nov 29, 2018 4:16 am Post subject: |
although it is better than corgi and busch it is still flawed in big ways, the rear window is not shaped right, the windshield is close but the glaring flaw for me is what manufacturers call the A pillar, the very front pillar to the roof on these are wider than on the real bus. I would have been happy to have these in 2000 but as Rapido Trains has made an almost perfect version I cannot go with this. I settled for corgis and buschs because I was desperate then. but with the bus being bigger it would kill me to look at the mistake. What many people do not see is how the driver's window is since it is close to the front which tapers so the front edge is not in line with the rest of the bus. Now another taper, the one where the bus tapers greatly at the top means that the window also is not perfectly vertical as the other windows are. The window leans in at the top. If you look at pictures of a fishbowl bus against the picture of a toy you will see this.
From the inside of the bus the windshield and driver's window overlaps. there is a very skinny pillar between the driver's window and the windshield.
| Back to top |
Age: 79 Joined: 01 Feb 2011 Posts: 748 Location: St. Peters, Mo.
Posted: Mon Jan 14, 2019 8:02 pm Post subject: |
The biggest flaw that you overlooked are the 5303 taillights that don't belong on this first generation newlook. Why IXO didn't keep the 5301 taillights for this model as a carryover from their other buses doesn't make sense.
Otherwise, despite all the flaws you described of which I 100% agree with, I had to add this model to my collection. It's better than nothing despite its shortcomings.
Let's hope their next bus is a Flxible newlook.
| Back to top |
Posted: Mon Jun 03, 2019 8:45 pm Post subject: |
Look at what the New York City Transit Museum is offering for sale...
This is the same bus that IXO produced before, but now they have added the batwings.
Same flaws as before but this time they have added the mistake of a "TA" emblem with a MaBSTOA fleet number, 8456.
Price tag: $89.99
| Description: |
| Filesize: |
66.45 KB |
| Viewed: |
82461 Time(s) |
| Description: |
| Filesize: |
65.79 KB |
| Viewed: |
82461 Time(s) |
| Back to top |
Posted: Thu Jun 06, 2019 10:41 pm Post subject: |
A two tone blue version is also available.
| Description: |
| Filesize: |
120.87 KB |
| Viewed: |
82432 Time(s) |
| Description: |
| Filesize: |
96.54 KB |
| Viewed: |
82432 Time(s) |
| Back to top |
Posted: Sun Dec 29, 2019 9:15 pm Post subject: |
Iconic Replicas is introducing the third series of New York City "New Look" buses with batwings.
This time it is in the white and blue scheme.
They have changed the corner marker lights to the correct TDH-5303 bullet shape lights. However, they still have the emergency door. They did changed the window panes on the rear door to two instead of the four they used on the green version of this bus.
The only real problem is that fleet number 8854 was a T6H-5305A and not a TDH-5303!
Suggested retail price... $79.95
| Description: |
| Filesize: |
29.49 KB |
| Viewed: |
80846 Time(s) |
| Description: |
| Filesize: |
19.95 KB |
| Viewed: |
80846 Time(s) |
| Back to top |
Posted: Sun Dec 29, 2019 9:16 pm Post subject: |
Here are three more views of this diecast model
| Description: |
| Filesize: |
24.44 KB |
| Viewed: |
80843 Time(s) |
| Description: |
| Filesize: |
16.35 KB |
| Viewed: |
80845 Time(s) |
| Description: |
| Filesize: |
15.31 KB |
| Viewed: |
80845 Time(s) |
| Back to top |
Posted: Sun Dec 29, 2019 9:21 pm Post subject: |
They are also releasing a non-decorated model TDH-5303 with air conditioning and a roof-top radio blister.
The standee windows should come to an end with the first window and not even with the quarter window.
| Description: |
| Filesize: |
16.34 KB |
| Viewed: |
80842 Time(s) |
| Description: |
| Filesize: |
133.22 KB |
| Viewed: |
80842 Time(s) |
| Description: |
| Filesize: |
17.09 KB |
| Viewed: |
80842 Time(s) |
| Back to top |
